It is currently Mon Jul 07, 2025 10:27 pm
PostPosted: Fri Sep 30, 2016 6:59 am
Maybe I'll get some joy here.
Someone brought one in, bridge 3/4 detached and a bit cupped
Looks like the bridge was glued to the finish, which is still sound (so far as I can see under the bridge - 1980's, polyester?)
Guesses as to the glue they used?
PostPosted: Fri Sep 30, 2016 8:02 am
My guess would be some sort of pva glue. Can you see if it melted the finish underneath or I is it mostly intact?
PostPosted: Fri Sep 30, 2016 10:52 am
CA is often the glue used to glue directly to polyester. That's what Rick Turner used/uses.
PostPosted: Fri Sep 30, 2016 8:54 pm
First name: Freeman
Last Name: Keller
Whatever glue is on there now should be completely removed as should the finish. Once you have have good wood to wood then a wood working glue (HHG, Titebond) should work fine
PostPosted: Sat Oct 01, 2016 2:14 am
I understand the sentiment, but this is probably a "pro bono" job (I used to own one) and would like to keep this in it's pristine original condition.
Besides, the top is best quality ply, and the finish may be helping holding it together. laughing6-hehe
PostPosted: Sat Oct 01, 2016 10:43 am
First name: Freeman
Last Name: Keller
I am a hobby repair person and probably the second most common repair I do is reglued bridges. I have a whole gallery of pictures of bad factory glue jobs - here is a Fender acoustic and yes, that is finish
Paint stripper and a little chiseling
This is what Fender thought was the right amount of glue
This guitar isn't worth much, but if its worth fixing its worth fixing right.
These users thanked the author Freeman for the post: Colin North (Sat Oct 01, 2016 1:57 pm)
PostPosted: Sat Oct 01, 2016 2:18 pm
Freeman, couldn't agree more. Doesn't matter what type of guitar it is or how much it's worth, there is only one way to do a repair and that is the right way.
These users thanked the author SteveSmith for the post: Colin North (Sat Oct 01, 2016 5:34 pm)
PostPosted: Fri Oct 14, 2016 3:45 pm
No choice now I've got the bridge off.
Found the bridge was put on with a gob of clue in the front to middle of the bridge, and it lifted the finish off with it. What I was seeing was the finish behind the said gob at the rear.
About 1/4-3/8" clear of glue all the way from the wings around the back.
Fortunately, the varnish has only pulled up some tiny fibres of the top wood with it, and those are in the middle of the bridge area.
PostPosted: Sat Oct 15, 2016 6:33 am
Looks like it came up pretty clean - nice! Can't believe that bridge held on when it was glued so poorly.
PostPosted: Sat Oct 15, 2016 6:38 am
Lucky
